Salta al contenuto principale
Disassembling Ericsson CF 388 Phone Casing
Cosa ti serve
  1. Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: passo 1, immagine 1 di 3 Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: passo 1, immagine 2 di 3 Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: passo 1, immagine 3 di 3
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Phone Casing, Phone Casing: passo 2, immagine 1 di 3 Disassembling Ericsson CF 388 Phone Casing, Phone Casing: passo 2, immagine 2 di 3 Disassembling Ericsson CF 388 Phone Casing, Phone Casing: passo 2, immagine 3 di 3
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
  3. Disassembling Ericsson CF 388 Phone Casing: passo 3, immagine 1 di 3 Disassembling Ericsson CF 388 Phone Casing: passo 3, immagine 2 di 3 Disassembling Ericsson CF 388 Phone Casing: passo 3, immagine 3 di 3
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
  4. Disassembling Ericsson CF 388 Phone Casing: passo 4, immagine 1 di 2 Disassembling Ericsson CF 388 Phone Casing: passo 4, immagine 2 di 2
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
Conclusione
Altre 2 persone hanno completato questa guida.
Clemson, Team 1-1, Benson Spring 2012 Membro di Clemson, Team 1-1, Benson Spring 2012
CLEM-BENSON-S12S1G1
3 Membri
21 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,261
