Salta al contenuto principale
Disassembling Dell Inspiron One 2020 Back Cover
Cosa ti serve
  1. Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: passo 1, immagine 1 di 3 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: passo 1, immagine 2 di 3 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: passo 1, immagine 3 di 3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Disassembling Dell Inspiron One 2020 Back Cover: passo 2, immagine 1 di 3 Disassembling Dell Inspiron One 2020 Back Cover: passo 2, immagine 2 di 3 Disassembling Dell Inspiron One 2020 Back Cover: passo 2, immagine 3 di 3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Disassembling Dell Inspiron One 2020 Back Cover: passo 3, immagine 1 di 3 Disassembling Dell Inspiron One 2020 Back Cover: passo 3, immagine 2 di 3 Disassembling Dell Inspiron One 2020 Back Cover: passo 3, immagine 3 di 3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
Conclusione
Altre 28 persone hanno completato questa guida.
Tyler
Membro da: 06/19/12
4.920 Reputazione
16 Guide realizzate
TechForce Membro di TechForce
Business
2 Membri
25 Guide realizzate
Un commento
I took the back cover off because everytime i connected the power cable the blue light on the power cable would go out and in taking off the back cover i might find something obvious. I did not find anything obvious except for a plastic clip floating around by itself. this may be the cause to a short i am thinking. Any ideas?
kim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 57
Tutti i Tempi: 33,857
