Parti
Nessuna parte richiesta.
  1. Remove all four screws on the side of camera with speaker.
    • Remove all four screws on the side of camera with speaker.
  2. Remove all four screws from side of camera with wristband attachment.
    • Remove all four screws from side of camera with wristband attachment.
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Remove all four screws on bottom of camera.
    • Remove all four screws on bottom of camera.
    • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly.
  5. Once all screws have been removed, gently pry open bottom casing. With tweezers, carefully remove ribbon from LCD screen. Set bottom casing aside.
    • Once all screws have been removed, gently pry open bottom casing.
    • With tweezers, carefully remove ribbon from LCD screen.
    • Set bottom casing aside.
  6. Pry apart the top casing using tweezers. Set the top casing aside.
    • Pry apart the top casing using tweezers.
    • Set the top casing aside.
Conclusione
Altre 2 persone hanno completato questa guida.
Logan
Membro da: 10/01/2011
311 Reputazione
2 Guide realizzate
Cal Poly, Team 4-38, Regan Winter 2011 Membro di Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Membri
7 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,799
