Introduzione
How to remove the outer casing of your Canon PowerShot SD850 IS.
Strumenti
Parti
Nessuna parte richiesta.
Using your fingernail, slide the light gray tab towards edge of camera.
Slide the light gray door and pull up to open the door.
Both Battery and Memory Card slots should be visible.
Remove the following 4 screws:
Two 2.8 mm Phillips #00 at the bottom of the camera.
Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
Altre 3 persone hanno completato questa guida.
Un commento
Had to exchange a battery/SD card cover on an Ixus970IS. This guide very helpful showing the way due to similar layout of the Ixus and the PS850IS! Thanx a lot! :-)
KBK Copenhagen DK
