Salta al contenuto principale
Introduzione
Removing the front cover allows access to the flash assembly.
Parti
Nessuna parte specificata.
  1. Remove one 2.25mm screw on the bottom.
    • Remove one 2.25mm screw on the bottom.
  2. Remove two 2.25mm screws on the right side looking from the front.
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Remove one 4.7mm screw on the side with the AV output.
    • Remove one 4.7mm screw on the side with the AV output.
  4. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  5. Pull off the back cover.
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  6. Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
    • Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
  7. Remove one 2.25mm screw on the bottom of the camera.
    • Remove one 2.25mm screw on the bottom of the camera.
  8. Pull off the front cover.
    • Pull off the front cover.
Conclusione
Jeremy Rabaino
Membro da: 10/10/2010
135 Reputazione
6 Guide realizzate
Cal Poly, Team 20-9, Maness Fall 2010 Membro di Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,291
