Salta al contenuto principale
Disassembling Canon PowerShot S50 Outer Casing
Cosa ti serve
  1. Disassembling Canon PowerShot S50 Outer Casing, Battery: passo 1, immagine 1 di 2 Disassembling Canon PowerShot S50 Outer Casing, Battery: passo 1, immagine 2 di 2
    • Place camera LCD side up and press up on the battery door.
    • Let it swing open until you can see the battery inside.
  2. Disassembling Canon PowerShot S50 Outer Casing: passo 2, immagine 1 di 1
    • Press down on the orange plastic.
    • This will gently eject the battery from its compartment.
  3. Disassembling Canon PowerShot S50 Outer Casing: passo 3, immagine 1 di 2 Disassembling Canon PowerShot S50 Outer Casing: passo 3, immagine 2 di 2
    • Holding the edges, slide out the battery.
  4. Disassembling Canon PowerShot S50 Outer Casing, Front Panel/Battery Door: passo 4, immagine 1 di 1
    • Look at the camera from the side with the lanyard and 4 screws.
    • Remove the two 3.4 mm screws on the metallic colored part.
  5. Disassembling Canon PowerShot S50 Outer Casing: passo 5, immagine 1 di 1
    • Remove the 3mm screw on the top left.
    • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
    • Now remove the 5.3mm screw on the bottom.
  6. Disassembling Canon PowerShot S50 Outer Casing: passo 6, immagine 1 di 1
    • Place the camera LCD side down.
    • Remove the two 5.3mm screws by the battery door.
  7. Disassembling Canon PowerShot S50 Outer Casing: passo 7, immagine 1 di 1
    • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
    • Make sure to keep these screws separate from the previous 5.3 mm screws.
  8. Disassembling Canon PowerShot S50 Outer Casing: passo 8, immagine 1 di 1
    • Stand the camera back up.
    • Remove the two 3.6mm screws on the side with the A/V Out port.
  9. Disassembling Canon PowerShot S50 Outer Casing: passo 9, immagine 1 di 1
    • Lift open the rubber flap covering the A/V Out port.
    • Remove the 3.4mm screw in the center.
    • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
  10. Disassembling Canon PowerShot S50 Outer Casing: passo 10, immagine 1 di 1
    • Use a spudger and gently open up the front panel of the camera.
    • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
  11. Disassembling Canon PowerShot S50 Outer Casing: passo 11, immagine 1 di 1
    • There will be a brown plastic piece keeping the thin plastic ribbon in place.
    • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
  12. Disassembling Canon PowerShot S50 Outer Casing: passo 12, immagine 1 di 1
    • Use a pair of tweezers and remove the metal piece inside the camera.
  13. Disassembling Canon PowerShot S50 Outer Casing: passo 13, immagine 1 di 1
    • Remove the battery door
    • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
  14. Disassembling Canon PowerShot S50 Outer Casing, Outer Casing: passo 14, immagine 1 di 1
    • Using a spudger, gently separate the back panel from the rest of the camera and remove it.
Conclusione
Karim
Membro da: 04/12/12
24 Reputazione
3 Guide realizzate
Cal Poly, Team 7-34, Maness Spring 2012 Membro di Cal Poly, Team 7-34, Maness Spring 2012
CPSU-MANESS-S12S7G34
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,623
