Salta al contenuto principale
Disassembling Canon Pixma MP480 Rear and Side Panel
Cosa ti serve
  1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: passo 1, immagine 1 di 2 Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: passo 1, immagine 2 di 2
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 2, immagine 1 di 1
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
  3. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 3, immagine 1 di 1
    • Open the front tray.
  4. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 4, immagine 1 di 2 Disassembling Canon Pixma MP480 Rear and Side Panel: passo 4, immagine 2 di 2
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 5, immagine 1 di 2 Disassembling Canon Pixma MP480 Rear and Side Panel: passo 5, immagine 2 di 2
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 6, immagine 1 di 2 Disassembling Canon Pixma MP480 Rear and Side Panel: passo 6, immagine 2 di 2
    • Pry open the side cover with the plastic opening tool.
  7. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 7, immagine 1 di 2 Disassembling Canon Pixma MP480 Rear and Side Panel: passo 7, immagine 2 di 2
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 8, immagine 1 di 2 Disassembling Canon Pixma MP480 Rear and Side Panel: passo 8, immagine 2 di 2
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
Conclusione
Altre 6 persone hanno completato questa guida.
Kevin Cole
Membro da: 01/17/13
116 Reputazione
1 Guida realizzata
Cal Poly, Team 19-41, Regan Winter 2013 Membro di Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Membri
6 Guide realizzate
2 Commenti
Where is the rest of disassembly?
bill roberts - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 21,143
