Salta al contenuto principale
Disassembling Canon EOS Rebel XS Front Cover
Cosa ti serve
  1. Disassembling Canon EOS Rebel XS Front Cover, Latch Side Cover: passo 1, immagine 1 di 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Front Cover: passo 2, immagine 1 di 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Front Cover, Disassembling Canon EOS Rebel XS Front Cover: passo 3, immagine 1 di 1
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Front Cover: passo 4, immagine 1 di 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
Conclusione
Altre 2 persone hanno completato questa guida.
Daniel Bussone
Membro da: 01/28/11
1.251 Reputazione
11 Guide realizzate
Cal Poly, Team 3-41, Regan Winter 2011 Membro di Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Membri
21 Guide realizzate
2 Commenti
This should be labelled: Easy.
tjt263 - Replica
Okay, there are several steps missing.
tjt263 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 5,275
