Salta al contenuto principale
Disassembling Canon EOS Rebel XS Battery Door
Cosa ti serve
  1. Disassembling Canon EOS Rebel XS Battery Door, Latch Side Cover: passo 1, immagine 1 di 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Battery Door: passo 2, immagine 1 di 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Battery Door, Disassembling Canon EOS Rebel XS Front Cover: passo 3, immagine 1 di 1
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Battery Door: passo 4, immagine 1 di 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Disassembling Canon EOS Rebel XS Battery Door, Grip: passo 5, immagine 1 di 1
    • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
  6. Disassembling Canon EOS Rebel XS Battery Door: passo 6, immagine 1 di 1
    • Use your fingertip to pry off the external shutter port cover.
  7. Disassembling Canon EOS Rebel XS Battery Door: passo 7, immagine 1 di 1
    • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
  8. Disassembling Canon EOS Rebel XS Battery Door: passo 8, immagine 1 di 3 Disassembling Canon EOS Rebel XS Battery Door: passo 8, immagine 2 di 3 Disassembling Canon EOS Rebel XS Battery Door: passo 8, immagine 3 di 3
    • Use the spudger tool to carefully pry the grip from the rest of the camera.
  9. Disassembling Canon EOS Rebel XS Battery Door: passo 9, immagine 1 di 1
    • Once the grip is loose, use your fingers to remove it from the camera.
  10. Disassembling Canon EOS Rebel XS Battery Door, Battery Door: passo 10, immagine 1 di 1
    • Remove the 4.8mm (.19in) long silver screw from the inside of the grip.
  11. Disassembling Canon EOS Rebel XS Battery Door: passo 11, immagine 1 di 2 Disassembling Canon EOS Rebel XS Battery Door: passo 11, immagine 2 di 2
    • Remove the hinge of the battery door from the inside of the grip.
    • Our sample camera's battery door was broken off of its hinge. Picture two shows an example of a battery door that is not broken.
Conclusione
Daniel Bussone
Membro da: 01/28/11
1.251 Reputazione
11 Guide realizzate
Cal Poly, Team 3-41, Regan Winter 2011 Membro di Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 4,987
