Salta al contenuto principale
Disassembling Canon EOS Digital Rebel XT (350D) Cover
Cosa ti serve
  1. Disassembling Canon EOS Digital Rebel XT (350D) Cover, Cover: passo 1, immagine 1 di 1
    • Make sure to remove the battery to avoid any harm to yourself or the camera.
    • At the bottom of the camera, there are 5 screws. Use the Phillips #00 head to remove all 5 screws
  2. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 2, immagine 1 di 1
    • Use your thumbs and push up to gently remove the eye lens cover.
  3. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 3, immagine 1 di 1
    • Remove the 2 screws under the eye lens cover using the Phillips #00 head.
  4. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 4, immagine 1 di 1
    • Turn the camera to the left side and use Phillips #00 head to unscrew the the top and bottom screws of the panel.
  5. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 5, immagine 1 di 1
    • There is another screw on top of the panel on the left side of the camera. Use Phillips #00 head to remove it.
  6. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 6, immagine 1 di 1
    • Turn on the camera on the right side and use Phillips #00 head to remove the 2 screws parallel from one another.
  7. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 7, immagine 1 di 1
    • There is another screw on top of the panel on the right side of the camera. Use Phillips #00 head to remove it.
  8. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 8, immagine 1 di 1
    • Open the memory card port and take out the CompactFlash from the inside. Upon removing the flash remove the 3 screws with a Phillips #00 head.
  9. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 9, immagine 1 di 1
    • Carefully remove the back camera cover with your fingers.
  10. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 10, immagine 1 di 2 Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 10, immagine 2 di 2
    • Gently remove the orange ribbon cable from the motherboard using your hands or tweezers. Carefully detach the orange ribbon cable connector from the body of the camera.
  11. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 11, immagine 1 di 1
    • Looking at the front side of the camera, remove the 2 screws below the Canon flash with a Phillips #00 head.
    • Make sure to avoid touching the lens itself directly to prevent scratches or dirt.
  12. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 12, immagine 1 di 1
    • Remove the screw at the bottom of the camera lens with a Phillips #00 head.
  13. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 13, immagine 1 di 1
    • Use the Phillips #00 head to remove the diopter adjustment dial’s screw at the top right of the eye lens.
  14. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 14, immagine 1 di 2 Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 14, immagine 2 di 2
    • Use a pry tool to remove the front casing of the camera Then, carefully pull the lens cover off the front of the camera.
  15. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 15, immagine 1 di 1
    • On the right side of the camera, remove the screw underneath the shutter-release button with the Phillips #00 head.
  16. Disassembling Canon EOS Digital Rebel XT (350D) Cover: passo 16, immagine 1 di 1
    • Finally, use your hands to carefully detach the top cover from the camera.
Conclusione
Briley Brewer
Membro da: 11/05/24
313 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 68
Tutti i Tempi: 190
