Introduzione
This is a fairly straight-forward process. You may be able to get away without removing the rear rubber grip.
Cosa ti serve
Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
Repeat for the other two grips
Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
Optionally throw the balled up adhesive at people pretending its a booger :)
Altre 3 persone hanno completato questa guida.
