Salta al contenuto principale
Disassembling Breville BKC600XL Coffee Brewer Head
Cosa ti serve
  1. Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: passo 1, immagine 1 di 3 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: passo 1, immagine 2 di 3 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: passo 1, immagine 3 di 3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Disassembling Breville BKC600XL Coffee Brewer Head, "Top" Black Shell Piece: passo 2, immagine 1 di 1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: passo 3, immagine 1 di 3 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: passo 3, immagine 2 di 3 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: passo 3, immagine 3 di 3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
Conclusione
Antonio
Membro da: 09/26/12
120 Reputazione
6 Guide realizzate
Cal Poly, Team 1-3, Propen Fall 2012 Membro di Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Membri
6 Guide realizzate
2 Commenti
Thanks so much for posting this! I was ready to throw my Breville out the window! Step three highlighted the closing mechanism and I was able to easily repair my machine!!
Thanks
acaltab - Replica
Does anyone know the name of the orange piece? And where I can get just that piece?
Ursula Nawab - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 4,188
