Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
The outer casing must be removed to replace any internal component of the Blackberry 8820.
To remove the outer casing of the Blackberry 8820, you must have a 1/16 inch diameter torx screwdriver ready as well as a plastic removing tool.
Parti
Nessuna parte specificata.
  1. Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. Remove the battery by prying under it with your finger or the plastic opening tool. Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. Use a nylon spudger to carefully remove the two side bars of plastic. Use a nylon spudger to carefully remove the two side bars of plastic.
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. Use a nylon spudger to carefully pry the back casing off.
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  5. Pry off the front casing.
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
Conclusione
ryan
Membro da: 12/04/2013
44 Reputazione
5 Guide realizzate
Cal Poly, Team 13-64, Johann Spring 2013 Membro di Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 20
Tutti i Tempi: 743
