Salta al contenuto principale
Parti
Nessuna parte specificata.
  1. Carefully slide battery cover off in a downward direction. Using the plastic opening tool, remove the battery. Light force may be necessary. Using the plastic opening tool, remove the battery. Light force may be necessary.
    • Carefully slide battery cover off in a downward direction.
    • Using the plastic opening tool, remove the battery. Light force may be necessary.
  2. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  3. Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
    • Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
  4. Using the plastic opening tool, carefully lift the back cover off.
    • Using the plastic opening tool, carefully lift the back cover off.
Conclusione
Ashley
Membro da: 12/02/2013
9 Reputazione
3 Guide realizzate
Ohio State, Team 1-1, Buehl Spring 2013 Membro di Ohio State, Team 1-1, Buehl Spring 2013
OSU-BUEHL-S13S1G1
3 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 239
