Salta al contenuto principale
Disassembling BT Baby Monitor 250 Power switch
Cosa ti serve
  1. Disassembling BT Baby Monitor 250 Power switch, Remove battery cover and batteries: passo 1, immagine 1 di 1
    • Unclip the battery cover, and remove the batteries (they're a tight fit - the purple ribbon should help though)
    • Remove the two phillips screws at the lower edge of the battery compartment
  2. Disassembling BT Baby Monitor 250 Power switch, Separate the casing: passo 3, immagine 1 di 1
    • The casing is now held together by a pair of snap-fixings on each side, which will require careful prising apart.
    • Using the picture as a guide to show where the catches are (red circles), use a small screwdriver or a spudger-type tool to release them levering outwards, then carefully separate the two halves of the casing
  3. Disassembling BT Baby Monitor 250 Power switch, Release the LCD: passo 4, immagine 1 di 1
    • The LCD is held on by a pair of small plastic lugs, one each side. Release these one at a time, while gently lifting the LCD up from the board.
    • Once both clips are released, it will hinge forward and down.
  4. Disassembling BT Baby Monitor 250 Power switch, Release PCB from case: passo 5, immagine 1 di 1
    • Remove the two screws from under the LCD
    • Remove the single screw in the middle of the lower part of the PCB
    • Gently bend up the two charging connectors on the lower edge of the PCB that stick through the case to free it
    • Lift the PCB from the case, lower edge first
  5. Disassembling BT Baby Monitor 250 Power switch, Inspect and repair loose switches: passo 6, immagine 1 di 1
    • With the PCB removed, inspect the switches along the top edge.
    • On mine, the solder holding the switch mounting tabs to the PCB had failed, leaving both tabs and pads intact
    • Carefully resolder these, ensuring enough heat is applied to ensure a good joint, but without damaging neighbouring components
    • Reassembly is the reverse of dismantling.
    • Remember to bend the charging connectors back into place so they are correctly seated
    • Replace the vibrate motor into its' groove.
    • Ensure the switches all operate correctly before clipping the two case halves back together - sometimes the little pieces of adhesive foam on the 'button pressers' need to be adjusted.
Conclusione
davidmpye
Membro da: 12/21/15
101 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,718
