Introduzione
How to disassemble the charger unit.
Slide the plug to release from the transformer unit
  • Slide the plug to release from the transformer unit
Aggiungi Commento
Slip a knife blade into the seam on one of the long edges. It should go in a fair way. Lever the lid upwards. It requires quite a bit of force to release. Be careful as the outer casing is flimsy and it will be deformed.
  • Slip a knife blade into the seam on one of the long edges. It should go in a fair way. Lever the lid upwards. It requires quite a bit of force to release. Be careful as the outer casing is flimsy and it will be deformed.
Aggiungi Commento
  • Once the lid comes off you can slide out the internals.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
ehfb
Membro da: 17/02/2015
61 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 31
Tutti i Tempi: 3,661
