Salta al contenuto principale
Disassembling Arnova 7K G3 Logic Board Ribbon Connectors
Cosa ti serve
  1. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: passo 1, immagine 1 di 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: passo 1, immagine 2 di 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: passo 1, immagine 3 di 3
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 2, immagine 1 di 2 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 2, immagine 2 di 2
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 3, immagine 1 di 1
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 4, immagine 1 di 2 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 5, immagine 1 di 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 5, immagine 2 di 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 5, immagine 3 di 3
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  6. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 6, immagine 1 di 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 6, immagine 2 di 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 6, immagine 3 di 3
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
Conclusione
Kue
Membro da: 03/18/15
301 Reputazione
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 436
