Salta al contenuto principale
Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel
Cosa ti serve
  1. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: passo 1, immagine 1 di 2 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: passo 1, immagine 2 di 2
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: passo 2, immagine 1 di 3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: passo 2, immagine 2 di 3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: passo 2, immagine 3 di 3
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: passo 3, immagine 1 di 1
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
Conclusione
Altre 8 persone hanno completato questa guida.
USF Tampa, Team 14-23, Meier Fall 2015 Membro di USF Tampa, Team 14-23, Meier Fall 2015
USFT-MEIER-F15S14G23
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 37
Tutti i Tempi: 13,638
