Salta al contenuto principale
Disassembling 1998-2002 Honda Accord Stereo Head Unit
Cosa ti serve
  1. Disassembling 1998-2002 Honda Accord Stereo Head Unit, Center Dash: passo 1, immagine 1 di 1
    • Before going any further: disconnect the battery. I keep a 10 mm wrench in my center console specifically for this purpose.
    • Use a 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
  2. Disassembling 1998-2002 Honda Accord Stereo Head Unit: passo 2, immagine 1 di 1
    • Note that the dash has been taken apart before, namely to install all those fancy gizmos you see in this picture.
    • The disassembly procedure is exactly the same for stock factory systems, but may differ when taking out the radio itself.
  3. Disassembling 1998-2002 Honda Accord Stereo Head Unit: passo 3, immagine 1 di 1
    • Use a #2 Philips screwdriver to remove the two screws holding the center of the dashboard in place.
  4. Disassembling 1998-2002 Honda Accord Stereo Head Unit: passo 4, immagine 1 di 2 Disassembling 1998-2002 Honda Accord Stereo Head Unit: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Spudger
    $3.99
    Compra
    • Use a spudger for the following step or, if you don't have one handy, cover a flathead screwdriver with a rag.
    • Gently insert a spudger or flathead screwdriver directly underneath the clock, just enough so you can pry out the clock. Perhaps a half inch or so will do it.
  5. Disassembling 1998-2002 Honda Accord Stereo Head Unit: passo 5, immagine 1 di 2 Disassembling 1998-2002 Honda Accord Stereo Head Unit: passo 5, immagine 2 di 2
    • Slide the clock out to expose a sole Phillips screw.
    • Alternatively, you can first disconnect the clock (see next step) and then proceed to remove the screw. It might be slightly easier to do that instead of the method you see here, but either way will work fine.
    • Remove the screw using your Phillips #2 screwdriver.
  6. Disassembling 1998-2002 Honda Accord Stereo Head Unit: passo 6, immagine 1 di 2 Disassembling 1998-2002 Honda Accord Stereo Head Unit: passo 6, immagine 2 di 2
    • Unplug the smaller connector first. There's a tab on top of the connector that you have to push downwards, then pull the connector. Make sure to grasp the connector itself, and not the wires.
    • Do the same with the larger connector. Again, there's a tab on top that needs to be pushed downward.
  7. Disassembling 1998-2002 Honda Accord Stereo Head Unit: passo 7, immagine 1 di 1
    • Now, gently pull the bottom of the center console towards you. Don't yank it out, there's two more connectors holding it in place.
  8. Disassembling 1998-2002 Honda Accord Stereo Head Unit: passo 8, immagine 1 di 2 Disassembling 1998-2002 Honda Accord Stereo Head Unit: passo 8, immagine 2 di 2
    • First take off the red connector. Just like before, there's a tab on top of the connector that you have to push downwards first.
    • Follow suit with the green connector.
    • Center dash can now be fully removed.
  9. Disassembling 1998-2002 Honda Accord Stereo Head Unit, Stereo Head Unit: passo 9, immagine 1 di 1
    • Remove the four screws (two on each side) holding the double-DIN stereo frame in place using a #2 JIS screwdriver or 8mm socket wrench.
  10. Disassembling 1998-2002 Honda Accord Stereo Head Unit: passo 10, immagine 1 di 1
    • Slide out the stereo head unit.
Conclusione
Altre 11 persone hanno completato questa guida.
3 Commenti
Great article!!!
It’s easy understand and install myself
Also, I would like to introduce to you a great article for the double din head unit as well as questions around it: http://speedfinal.com/double-din-head-un...
Grant Stella - Replica
Awesome detailed information step by step!!!
It’s helpful to install stereo system, I would like to share the double din head unit as well as buyer’s guide around it: https://consumercure.com/best-double-din...
CarStereoSystem - Replica
Really appreciate your words and details that you mentioned. you have given good detaisl about the wiring of the streaeo system. I want to share an article about 6x9 speakers and buyers guide.
https://www.7reviews.co/best-6x9-speaker...
briankya cathy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 35
Ultimi 30 Giorni: 111
Tutti i Tempi: 66,499
