Salta al contenuto principale
Dirt Devil Scorpion Quick Flip Filter Adapter Replacement
  1. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement, Filter Adapter: passo 1, immagine 1 di 2 Dirt Devil Scorpion Quick Flip Filter Adapter Replacement, Filter Adapter: passo 1, immagine 2 di 2
    • First, press the button on the handle of the vacuum to separate the two halves.
    • The button triggers a release mechanism, detaching the front half from the back of the vacuum.
  2. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: passo 2, immagine 1 di 1
    • Once the front half has been separated from the back half, locate the filter adapter.
    • The filter adapter is attached to the filter, locating the filter in this step will sufficiently locate the filter adapter.
    • Grasp the filter and adapter. Pull them out together.
  3. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: passo 3, immagine 1 di 2 Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: passo 3, immagine 2 di 2
    • Rotate the filter counterclockwise to remove it from the filter adapter.
    • Once the filter adapter has been removed from the filter, replace it.
Conclusione
Joseph Warner
Membro da: 11/11/17
201 Reputazione
2 Guide realizzate
IUPUI, Team S1-G1, Wilson Fall 2017 Membro di IUPUI, Team S1-G1, Wilson Fall 2017
IUPUI-WILSON-F17S1G1
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 497
