Salta al contenuto principale
Direct-Pull Cantilever Brake ("V-Brake") Maintenance
Cosa ti serve
  1. Direct-Pull Cantilever Brake ("V-Brake") Maintenance, Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 1, immagine 1 di 3 Direct-Pull Cantilever Brake ("V-Brake") Maintenance, Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 1, immagine 2 di 3 Direct-Pull Cantilever Brake ("V-Brake") Maintenance, Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 1, immagine 3 di 3
    • Squeeze the calipers together, and remove the brake cable.
  2. Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 2, immagine 1 di 3 Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 2, immagine 2 di 3 Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 2, immagine 3 di 3
    • Loosen the break caliper bolt, and remove the brake caliper.
  3. Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 3, immagine 1 di 2 Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 3, immagine 2 di 2
    • Inspect the brake pad. If the pad has worn down past the “wear line”, then it needs to be replaced.
  4. Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 4, immagine 1 di 3 Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 4, immagine 2 di 3 Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 4, immagine 3 di 3
    • Clean and lubricate the parts as necessary before reattaching the caliper arms.
    • Bolt the caliper arms back on while making sure the the pin on the back side of the caliper arm lines back up with the one of the holes in the frame. Each side should be in the same hole.
  5. Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 5, immagine 1 di 2 Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 5, immagine 2 di 2
    • Reattach the brake cable to the calipers
  6. Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 6, immagine 1 di 2 Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 6, immagine 2 di 2
    • Loosen the brake pad bolt.
  7. Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 7, immagine 1 di 2 Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 7, immagine 2 di 2
    • Get an ordinary piece of paper, and fold it twice over.
    • Place the sheet of paper between the brake pad and the rim in the position shown.
  8. Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 8, immagine 1 di 3 Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 8, immagine 2 di 3 Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 8, immagine 3 di 3
    • Align the brake pad so that it is flush with the rim, with no part touching the rubber of the tire.
    • Have somebody clamp down very tightly on the brakes.
    • Tighten the brake pad bolt in place.
  9. Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 9, immagine 1 di 3 Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 9, immagine 2 di 3 Direct-Pull Cantilever Brake ("V-Brake") Maintenance: passo 9, immagine 3 di 3
    • Tighten/loosen the tension adjustment screws on each the caliper arm to adjust the resting distance of each brake pad, so that each pad is equally distant from the rim. Tightening the screw will shift the caliper outward from the bike, loosening it will shift it inward.
    • Tighten/loosen the brake adjuster on the handle bars such that when you clamp down on the brakes, the brake lever stops before hitting the handle bar. This will set the distance between the brake pads and the rim.
    • Tighten the lock nut on the brake adjuster to permanently set its position.
Conclusione
Brett Hartt
Membro da: 04/12/10
131.199 Reputazione
143 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.618 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 6,355
