Salta al contenuto principale
Direct-Drive Turntable Cartridge and Needle Replacement
Cosa ti serve
  1. Direct-Drive Turntable Cartridge and Needle Replacement, Cartridge and Needle: passo 1, immagine 1 di 1
    • Check the needle and cartridge to see if they need to be replaced.
    • If the cartridge is touching your vinyl, it must be replaced.
    • Additionally, if you can hear scraping when playing the record, or if you see new scratch marks on the vinyl, it is time to change the cartridge and needle.
  2. Direct-Drive Turntable Cartridge and Needle Replacement: passo 2, immagine 1 di 3 Direct-Drive Turntable Cartridge and Needle Replacement: passo 2, immagine 2 di 3 Direct-Drive Turntable Cartridge and Needle Replacement: passo 2, immagine 3 di 3
    • Manually unscrew the bulb on the tone arm from the headshell.
    • Pull out the headshell once it is completely unscrewed from the tone arm.
  3. Direct-Drive Turntable Cartridge and Needle Replacement: passo 3, immagine 1 di 3 Direct-Drive Turntable Cartridge and Needle Replacement: passo 3, immagine 2 di 3 Direct-Drive Turntable Cartridge and Needle Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Use a 2.5 mm flathead screwdriver to remove both screws from the headshell.
  4. Direct-Drive Turntable Cartridge and Needle Replacement: passo 4, immagine 1 di 2 Direct-Drive Turntable Cartridge and Needle Replacement: passo 4, immagine 2 di 2
    • Gently pull the four wires out from the back of the cartridge.
  5. Direct-Drive Turntable Cartridge and Needle Replacement: passo 5, immagine 1 di 2 Direct-Drive Turntable Cartridge and Needle Replacement: passo 5, immagine 2 di 2
    • Pull the needle off of the new cartridge to ensure it does not get damaged during installation.
  6. Direct-Drive Turntable Cartridge and Needle Replacement: passo 6, immagine 1 di 3 Direct-Drive Turntable Cartridge and Needle Replacement: passo 6, immagine 2 di 3 Direct-Drive Turntable Cartridge and Needle Replacement: passo 6, immagine 3 di 3
    • Connect the wires on the headshell to the new cartridge by matching the colors of the wires to the pins on the cartridge.
    • Place the headshell back onto the cartridge, being sure to line up the holes for the screws.
    • Place the screws back into the holes connecting the headshell and the new cartridge.
  7. Direct-Drive Turntable Cartridge and Needle Replacement: passo 7, immagine 1 di 3 Direct-Drive Turntable Cartridge and Needle Replacement: passo 7, immagine 2 di 3 Direct-Drive Turntable Cartridge and Needle Replacement: passo 7, immagine 3 di 3
    • Screw the screws in using a 2.5 mm flathead screwdriver. Ensure the headshell is securely attached to the cartridge.
    • Slide the new needle back onto the cartridge.
  8. Direct-Drive Turntable Cartridge and Needle Replacement: passo 8, immagine 1 di 3 Direct-Drive Turntable Cartridge and Needle Replacement: passo 8, immagine 2 di 3 Direct-Drive Turntable Cartridge and Needle Replacement: passo 8, immagine 3 di 3
    • Attach the headshell to the tone arm and screw the headshell in from the tip of the tone arm.
    • Ensure that the headshell is secured in the tone arm and that there is no movement in the headshell when connected to the tone arm.
  9. Direct-Drive Turntable Cartridge and Needle Replacement: passo 9, immagine 1 di 1
    • Place the needle onto a vinyl record and ensure that only the tip of the needle is touching the record and not the cartridge.
  10. Direct-Drive Turntable Cartridge and Needle Replacement, Check alignment of the needle: passo 10, immagine 1 di 3 Direct-Drive Turntable Cartridge and Needle Replacement, Check alignment of the needle: passo 10, immagine 2 di 3 Direct-Drive Turntable Cartridge and Needle Replacement, Check alignment of the needle: passo 10, immagine 3 di 3
    • For good sound the needle has to fit parallel into the record groove. Othrewise the sound isn't leveled between left and right channel.
    • Therefore templates are available to buy or to print. They got orthogonal lines on the area where the needle is setting in and where it is setting off.
    • The needle should be parallel to the lines on the template at R120,9 mm. If not, the screws shown in step 3 can be loosened and the cartridge can be adjusted. After adjusting tight the screws up again.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,287
