Salta al contenuto principale
Dim Blue LED on Skullcandy Hesh 2 Wireless
Cosa ti serve
  1. Dim Blue LED on Skullcandy Hesh 2 Wireless, Remove Cushions: passo 1, immagine 1 di 1
    • Remove the cushion from both speakers.
  2. Dim Blue LED on Skullcandy Hesh 2 Wireless, Opening The Speaker: passo 2, immagine 1 di 2 Dim Blue LED on Skullcandy Hesh 2 Wireless, Opening The Speaker: passo 2, immagine 2 di 2
    • On the right speaker, remove the 4 screws shown.
    • Remove the plastic plate , but be careful not to damage the speaker wires.
  3. Dim Blue LED on Skullcandy Hesh 2 Wireless, Covering LEDs: passo 3, immagine 1 di 1
    • On the bottom left of the board, near the power button, are LED0 through LED3. The odd numbered LEDs are blue, and the even numbered LEDs are red.
    • With the sharpie, carefully mark the tops of the LEDs. Alternatively, if you want to black out the lights entirely, use very small pieces of electrical tape to cover them.
    • It's a good idea to verify the color of each LED by powering on the headset while it's open.
Conclusione
Altre 5 persone hanno completato questa guida.
Ian
Membro da: 12/07/18
1.474 Reputazione
2 Guide realizzate
Kid fixers Membro di Kid fixers
Community
154 Membri
291 Guide realizzate
4 Commenti
I just put a drop of nail polish in each led. i use deep red. with that color you still have let signal for on/off and low bat.
Francisco B - Replica
Buenas tardes mi problema con mis audífonos es que ya no prenden debido a una caída,lo cual se me hace raro ya que al querer prenderlos solo parpadean los led pero ya no se escucha el encendido...
Gracias espero tener respuesta
Kevin Lujano Torres - Replica
Quiero identificar que color de cables que van en su lugar tuve un problema y lo abrí todos los cables están despegados así que quiero identificar en que parte va cada uno espero y me puedan ayudar 😅
Yoni Lizárraga - Replica
Good job for documenting this repair, always helpful.
LagaiPhone - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 3,248
