Salta al contenuto principale
Digital2 Platinum Pad 9 External Cover Replacement
Cosa ti serve
  1. Digital2 Platinum Pad 9 External Cover Replacement, External Cover: passo 1, immagine 1 di 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 External Cover Replacement: passo 2, immagine 1 di 2 Digital2 Platinum Pad 9 External Cover Replacement: passo 2, immagine 2 di 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 External Cover Replacement: passo 3, immagine 1 di 2 Digital2 Platinum Pad 9 External Cover Replacement: passo 3, immagine 2 di 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 291
