Introduzione
We will be replacing the screen in the tablet by first taking the tablet apart. Dropping the tablet with no cover or protection is likely to result in a cracked screen.
Cosa ti serve
Wedge the opening tool in the space between the back and the front of the tablet.
Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
When the back of the tablet is mostly detached from the front, carefully pull it away completely.
Be sure to remove the yellow tape that is holding the components down.
Locate the two yellow ribbon cables and carefully remove by lifting the black tab connectors forward and slide out ribbon.
When all components are unsecured, you will be able to remove the battery, motherboard, camera, and speaker out of the way.
3Commenti sulla guida
Dear Lindsay,
thank you for the guide how to open up that little thing!
Apparently I have fried it after I had mislaid the charger and used my
universal charger without checking the voltage: 8 instead of 5... If only
I had used my reading glasses.
Is there something like a fuse that I could repair/exchange?
Thank you for your help!
Respectfully,
Wolfgang
Thanks for the help, I am just curious where I can get the new screen, I believe that the front glass is fine but the actual display I am pretty sure is not.
This website right here. Straight trash,basically So you have a broken tablet. You come to the website to get help to replace it. And it's no help at all. This is what I think about this hot mass right here
