Salta al contenuto principale
Digital2 D2-912 Camera Module Replacement
Cosa ti serve
  1. Digital2 D2-912 Camera Module Replacement, External Cover: passo 1, immagine 1 di 1
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Camera Module Replacement: passo 2, immagine 1 di 2 Digital2 D2-912 Camera Module Replacement: passo 2, immagine 2 di 2
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Camera Module Replacement, Camera Module: passo 3, immagine 1 di 1
    • Peel the black tape back and pull the black tab back (the tab should come up, not slide).
    • The camera module should then easily come out. Insert your replacement module.
Conclusione
Jason Wignot
Membro da: 09/16/15
322 Reputazione
3 Guide realizzate
IUPUI, Team 1-1, Harley Fall 2015 Membro di IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 135
