Salta al contenuto principale
Digital2 D2-861G Camera Replacement
Cosa ti serve
  1. Digital2 D2-861G Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
    • Place your device on a soft cloth to avoid scratching the screen
    • Flip your device over so back panel is facing upwards.
  2. Digital2 D2-861G Camera Replacement: passo 2, immagine 1 di 1
    • Do not use a lot of force as it can break the clips or the back panel.
    • Insert spudger in the slot below the micro SD card.
    • You should hear clips releasing as you pry along the edges.
    • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
  3. Digital2 D2-861G Camera Replacement: passo 3, immagine 1 di 1
    • Disconnecting the bundled cable connector helps avoid short circuiting anything on the device.
    • Locate the bundled cable connector and disconnect it by simply pulling it gently or using a spudger.
  4. Digital2 D2-861G Camera Replacement: passo 4, immagine 1 di 2 Digital2 D2-861G Camera Replacement: passo 4, immagine 2 di 2
    • Locate and unplug the flat-top connector from the motherboard..
    • To unplug the connector go under it with either side of the spudger and lift up.
  5. Digital2 D2-861G Camera Replacement: passo 5, immagine 1 di 2 Digital2 D2-861G Camera Replacement: passo 5, immagine 2 di 2
    • Avoid pulling the gold connector as it can be damaged and/or broken.
    • To remove the camera, simply use the pointed end of the spudger and insert it in the corner and gently lift.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 134
