Introduzione
This guide is on how to replace the soldering wire on a Taylor Digital Scale Model #7403. There is a loose connection within the scale that allows the scale to turn on but not function as it should. The replacement of this soldering wire is needed so that the scale can operate properly. You will need some knowledge of soldering.
Cosa ti serve
If your scale turns on and works properly but once you use it then it turns off, then it is likely there is a loose connection that needs to be replaced.
