Salta al contenuto principale
Digiland 10.1'' DL1016 Screen Replacement
Cosa ti serve
  1. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Backing: passo 1, immagine 1 di 2 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Backing: passo 1, immagine 2 di 2
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Screen Replacement: passo 2, immagine 1 di 2 Digiland 10.1'' DL1016 Screen Replacement: passo 2, immagine 2 di 2
    • Gently lift the backing off.
  3. Attenzione: il passaggio 3 proviene da una guida contrassegnata come in corso.
    Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: passo 3, immagine 1 di 2 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: passo 3, immagine 2 di 2
    • Gently pull the wiring back.
    • You may need to use a metal spudger to lift the wire connector off the back of the screen.
  4. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Battery: passo 4, immagine 1 di 2 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Battery: passo 4, immagine 2 di 2
    • Use an ESD safe pryer to lift the battery up.
    • There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
  5. Digiland 10.1'' DL1016 Screen Replacement, Power Button: passo 5, immagine 1 di 1
    • Disconnect the black cable off the motherboard.
    • Remove the four 1.5mm Phillips #000 screws from the motherboard.
  6. Digiland 10.1'' DL1016 Screen Replacement: passo 6, immagine 1 di 2 Digiland 10.1'' DL1016 Screen Replacement: passo 6, immagine 2 di 2
    • Make sure the ribbon cables are free or unconnected so the motherboard is able to be moved.
    • Use a metal spudger to slide underneath the motherboard and push it up so it's unstuck from the tablet.
    • Lift up the motherboard and place it somewhere that is clean and kept safe.
  7. Digiland 10.1'' DL1016 Screen Replacement, Screen: passo 7, immagine 1 di 2 Digiland 10.1'' DL1016 Screen Replacement, Screen: passo 7, immagine 2 di 2
    • Remove the tape from the backside of the tablet along with the wiring.
    • Make space so you can pry the motherboard away from the digitizer.
  8. Digiland 10.1'' DL1016 Screen Replacement: passo 8, immagine 1 di 2 Digiland 10.1'' DL1016 Screen Replacement: passo 8, immagine 2 di 2
    • Once the motherboard is pulled away, the screen should be free of all other components.
    • Check around the edges so that no tape is stuck to the edges or wiring and just push off digitizer and replace screen if needed.
Conclusione
Gateway, Team S1-G2, Saknee Fall 2019 Membro di Gateway, Team S1-G2, Saknee Fall 2019
GCC-SAKNEE-F19S1G2
4 Membri
5 Guide realizzate
3Commenti sulla guida
Where can i get the screen for this tablet? i need to order online and currently i am in india.
Arivu Alagan - Replica
Where will I get screen in kenya
Josphat Mutai - Replica
My phone crack,I need screen only
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,059
