Cosa ti serve
Passo 1 Digiland 10.1'' DL1016 Remove Backing
Attenzione: i passaggi 1-2 provengono da una guida contrassegnata come in corso.
Use an opening pick and an opening tool to pry the backing off the back of the tablet.
Pull back the black flaps on the ZIF cable connectors.
Pull the ribbon cables out of the connectors.
Passo 4 Digiland 10.1'' DL1016 Remove Battery
Attenzione: il passaggio 4 proviene da una guida contrassegnata come in corso.
There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
Un commento
Where I can buy this battery ? From the screenshot it looks to be a fit for a Tanoshi 2 in 1 computer
