Salta al contenuto principale
DigiTech RP70 Motherboard Replacement
Cosa ti serve
  1. DigiTech RP70 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 DigiTech RP70 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 Motherboard Replacement: passo 2, immagine 1 di 2 DigiTech RP70 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 Motherboard Replacement: passo 4, immagine 1 di 1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
Conclusione
4Commenti sulla guida
My digitech rp 80 not work. How to get new motherboard
Thadevus - Replica
My digitecj rp 80 not working. No display no sound how to get new motherboard
Thadevus - Replica
Does anyone know where I can get the tone library push button/knob assy? Mine broke off.
Michael Adkins - Replica
Quiero comprar una estoy en Ecuador. Quiero comprar la moterboard
Lenin Omar Guerra Chango - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,139
