Salta al contenuto principale
DigiLand DL8006 Speaker Replacement
Cosa ti serve
  1. DigiLand DL8006 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Begin by opening the device around its edge using the iFixit opening tool.
  2. DigiLand DL8006 Speaker Replacement: passo 2, immagine 1 di 2 DigiLand DL8006 Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the metallic tape that covers the lower section of the battery.
  3. DigiLand DL8006 Speaker Replacement: passo 3, immagine 1 di 2 DigiLand DL8006 Speaker Replacement: passo 3, immagine 2 di 2
    • Remove the three battery screws using a Phillips #0 screwdriver.
  4. DigiLand DL8006 Speaker Replacement: passo 4, immagine 1 di 3 DigiLand DL8006 Speaker Replacement: passo 4, immagine 2 di 3 DigiLand DL8006 Speaker Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Pop up the locking tab of the ZIF connector using tweezers, and carefully pull the cable out from the motherboard.
    • Make sure the ribbon passes under the microphone wiring to avoid damage to the components.
    • Remove the lower section of the ribbon cable repeating the previous bullet.
  5. DigiLand DL8006 Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the battery from the phone using the iFixit opening tool or the spudger.
  6. DigiLand DL8006 Speaker Replacement: passo 6, immagine 1 di 2 DigiLand DL8006 Speaker Replacement: passo 6, immagine 2 di 2
    • Finally, remove the speaker from the tablet using the spudger.
    • In this image, a screwdriver was used to pry the speaker from its housing. You should use an ESD-safe tool to avoid causing damage to your device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 137
