Salta al contenuto principale
DigiLand DL1010Q Rear Case Replacement
Cosa ti serve
  1. DigiLand DL1010Q Rear Case Replacement, Rear Case: passo 1, immagine 1 di 1
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
  2. DigiLand DL1010Q Rear Case Replacement: passo 2, immagine 1 di 2 DigiLand DL1010Q Rear Case Replacement: passo 2, immagine 2 di 2
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  3. DigiLand DL1010Q Rear Case Replacement: passo 3, immagine 1 di 1
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 521
