Introduzione
Replacing the circuit board can also be used as a way to fix broken ports.
Cosa ti serve
With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
Using a plastic opening tool, gently pry up the three Zero Insertion Force Connectors (ZIF)
Using a Soldering station, desolder all 9 wires connected to the motherboard.
Start with the red and black positive and negative wires connected to the battery (2 wires).
Then move to the yellow and red twisted wires and black and red twisted wires connected to the speakers (4 wires).
Now desolder the single grey wire connected to the antenna (1 wire).
Lastly remove the black and red wires connected to the microphone (2 wires).
Altre 2 persone hanno completato questa guida.
2 Commenti
How can I remove the CMOS battery?
I NEED dl1010q MOTHER BOARD
