Salta al contenuto principale
How to diagnose Samsung Galaxy A40 Charging Problems
Panoramica Video
  1. How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: passo 1, immagine 1 di 3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: passo 1, immagine 2 di 3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: passo 1, immagine 3 di 3
    • This is the +5V line from the Charging port to the Motherboard.
  2. How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: passo 2, immagine 1 di 3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: passo 2, immagine 2 di 3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: passo 2, immagine 3 di 3
    • Warm the device to soften the adhesive.
    • Use Sanction cup, Plastic tools and isopropyl alcohol.
    • Remove the silver Phillips screws from the device's frame.
  3. How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: passo 3, immagine 1 di 3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: passo 3, immagine 2 di 3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: passo 3, immagine 3 di 3
    • Remove the plastic cap from the Fingerprint flex cable connector and disconnect the cable.
    • Remove the SIM Tray.
  4. How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: passo 4, immagine 1 di 3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: passo 4, immagine 2 di 3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: passo 4, immagine 3 di 3
    • Use a plastic tool to separate the back cover from the frame. Start from the SIM tray hole.
    • Disconnect the battery.
  5. How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: passo 5, immagine 1 di 3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: passo 5, immagine 2 di 3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: passo 5, immagine 3 di 3
    • Disconnect the main flex cable and connect the charger.
    • Use a multimeter to measure the voltages at the large end pins of the FPC connector of the charging board. (See the second image)
    • If the reading is okay (~5V) continue with the next step, if not - change the Charging board.
    • Attach the main flex cable and measure the large end pins of the Main flex FPC connector - pic.3.
    • If the reading is okay, continue with the next step, if not - change the Main flex cable.
  6. How to diagnose Samsung Galaxy A40 Charging Problems: passo 6, immagine 1 di 3 How to diagnose Samsung Galaxy A40 Charging Problems: passo 6, immagine 2 di 3 How to diagnose Samsung Galaxy A40 Charging Problems: passo 6, immagine 3 di 3
    • Remove the adhesive rubber around the main flex connector on the logic board.
    • Use some flux and a soldering iron to re-solder the first pin of the motherboard FPC.
Conclusione
Altre 4 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.182 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.519 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 53
Ultimi 30 Giorni: 209
Tutti i Tempi: 7,914
