Salta al contenuto principale
Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable
Cosa ti serve
  1. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable, Unplug: passo 1, immagine 1 di 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 2, immagine 1 di 2 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 2, immagine 2 di 2
    • Remove the side handle and the protective cover.
  3. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 3, immagine 1 di 2 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 3, immagine 2 di 2
    • Unscrew the 4 screws to open the machine.
  4. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 4, immagine 1 di 3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 4, immagine 2 di 3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 4, immagine 3 di 3
    • Remove the switch from his housing in order to have access to it.
    • Unscrew the two screws to disconnect the cables.
  5. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 5, immagine 1 di 3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 5, immagine 2 di 3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 5, immagine 3 di 3
    • Replace the cable and reconnect the cables to the switch.
    • Be careful to put the sheath back between the two studs.
  6. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 6, immagine 1 di 1
    • Before closing, check that no cables are blocked.
    • Screw the 4 screws to close.
  7. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 7, immagine 1 di 2 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: passo 7, immagine 2 di 2
    • Replace the external flange, the protective cover and the side handle.
Linea Traguardo
Un ringraziamento speciale a questi traduttori:
fr en
100%
HelloMacOS ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Céline Chemineau
Membro da: 01/29/20
16.608 Reputazione
95 Guide realizzate
Leroy Merlin Membro di Leroy Merlin
Community
37 Membri
239 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 121
