Salta al contenuto principale
Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement
Cosa ti serve
  1. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement, Unplug: passo 1, immagine 1 di 1
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 2, immagine 1 di 1
    • Remove the seal on the back of the device.
  3. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 3, immagine 1 di 3 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 3, immagine 2 di 3 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 3, immagine 3 di 3
    • Unscrew the first screw of the pad.
    • Then unscrew the four remaining screws and pull up to remove it.
    • Finally, remove the screws located on the hull of the device.
    • This step is the same for both carbons.
    • Trap the two carbons to be able to take out the rotor. With a screwdriver to lift them up, then with another screwdriver press the tab.
    • Lift the carbons and with the other tip of the screwdriver, come twist the small paw.
    • Then remove the carbon.
    • Remove the rotor by lifting the frame to be able to retrieve it more easily.
  4. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 6, immagine 1 di 2 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 6, immagine 2 di 2
    • Use a soldering iron to weld the component's rotor.
    • De-solder at the location of the wires.
    • Then remove the wires one by one to remove the component.
  5. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 7, immagine 1 di 1
    • Return the new component to its location.
    • Then unfold the four threads in their place.
  6. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 8, immagine 1 di 3 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 8, immagine 2 di 3 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 8, immagine 3 di 3
    • Replace the rotor in its housing.
    • Unlock the carbons.
    • Replace the cable, the sheath must arrive between the two studs and the sleeve must be positioned in its housing.
  7. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 9, immagine 1 di 2 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 9, immagine 2 di 2
    • Replace the hull of the sander by being careful to properly position the stabilisers in their housing.
  8. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 10, immagine 1 di 3 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 10, immagine 2 di 3 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: passo 10, immagine 3 di 3
    • Replace the pad by positioning it perfectly in the tips.
    • Screw the four screws.
    • Then the last screw. Finally, put the joint back in its place.
Conclusione
To reassemble follow the steps in reverse.
Un ringraziamento speciale a questi traduttori:
fr en
100%
HelloMacOS ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Céline Chemineau
Membro da: 01/29/20
16.581 Reputazione
95 Guide realizzate
Leroy Merlin Membro di Leroy Merlin
Community
37 Membri
239 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 87
