Salta al contenuto principale
Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable
Cosa ti serve
  1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable, Unplug: passo 1, immagine 1 di 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 2, immagine 1 di 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 2, immagine 2 di 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 2, immagine 3 di 3
    • Remove the handle, by unscrewing the screw.
  3. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 3, immagine 1 di 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 3, immagine 2 di 2
    • Remove the strip by leverling.
  4. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 4, immagine 1 di 1
    • Unscrew the 4 screws.
  5. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 5, immagine 1 di 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 5, immagine 2 di 2
    • Remove the belt, then unscrew the screws from the shell to access the engine.
  6. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 6, immagine 1 di 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 6, immagine 2 di 2
    • Remove the screws from the hull to have access inside and allow the coals to be blocked.
    • Lift the speed variator, you can use a small screwdriver to get it out.
  7. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 8, immagine 1 di 2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 8, immagine 2 di 2
    • Turn the dimmer over to have good access to be able to unweld the wires.
    • Unweld the cables connected to the motor and suck the excess with a pump.
  8. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 10, immagine 1 di 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 10, immagine 2 di 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 10, immagine 3 di 3
    • Unscrew the two screws from the switch to extract the second cable.
    • To extract the cables you can use a clamp.
    • Change the speed variator and then disconnect the cable from the switch.
    • Reseating the motor cables to the dimmer.
  9. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 13, immagine 1 di 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 13, immagine 2 di 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 13, immagine 3 di 3
    • Replace the dimmer in its housing.
    • Be careful to put the cables back on so that it is not pinched.
  10. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 14, immagine 1 di 1
    • Screw the four screws.
  11. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 15, immagine 1 di 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 15, immagine 2 di 3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 15, immagine 3 di 3
    • Replace the tip, strip and handle.
Linea Traguardo
Un ringraziamento speciale a questi traduttori:
fr en
100%
HelloMacOS ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Céline Chemineau
Membro da: 01/29/20
16.608 Reputazione
95 Guide realizzate
Leroy Merlin Membro di Leroy Merlin
Community
37 Membri
239 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 172
