Salta al contenuto principale
Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System
Cosa ti serve
  1. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System, Unplug: passo 1, immagine 1 di 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 2, immagine 1 di 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 2, immagine 2 di 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 2, immagine 3 di 3
    • Remove the handle, unscrewing the screw
  3. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 3, immagine 1 di 2 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 3, immagine 2 di 2
    • Remove the strip by leverling
  4. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 4, immagine 1 di 1
    • Remove the front cover to have more space.
  5. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 5, immagine 1 di 1
    • Remove the two screws on the shell.
  6. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 6, immagine 1 di 1
    • Turn the machine over and unscrew the large screw.
    • Unscrew the orange wheel to be able to lift it.
  7. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 8, immagine 1 di 1
    • Remove the spring from the old part to put it back on the new one.
  8. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 9, immagine 1 di 1
    • Put the spring back.
    • Tighten the orange wheel.
  9. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 11, immagine 1 di 1
    • Put the two screws back on the side and the large screw.
  10. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 12, immagine 1 di 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 12, immagine 2 di 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 12, immagine 3 di 3
    • Replace the tip, strip and handle.
Linea Traguardo
Un ringraziamento speciale a questi traduttori:
fr en
100%
HelloMacOS ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Céline Chemineau
Membro da: 01/29/20
16.608 Reputazione
95 Guide realizzate
Leroy Merlin Membro di Leroy Merlin
Community
37 Membri
239 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 331
