Salta al contenuto principale
Dexter Corded Belt Sander - 900BS2.5 Motor Replacement
Cosa ti serve
  1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement, Unplug: passo 1, immagine 1 di 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 2, immagine 1 di 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 2, immagine 2 di 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 2, immagine 3 di 3
    • Remove the handle, by unscrewing the screw.
  3. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 3, immagine 1 di 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 3, immagine 2 di 2
    • Pry the tape off.
  4. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 4, immagine 1 di 1
    • Unscrew the 4 screws.
  5. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 5, immagine 1 di 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 5, immagine 2 di 2
    • Remove the belt, then unscrew the screws of the shell to gain access to the motor.
    • Collect the belt to place it in the new room.
  6. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 6, immagine 1 di 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 6, immagine 2 di 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 6, immagine 3 di 3
    • Remove both accessories.
  7. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 7, immagine 1 di 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 7, immagine 2 di 2
    • Remove the screws from the hull in order to have access to the interior and allow the carbon brushes to be blocked.
    • Relax the small metal strip to be able to separate the carbons.
    • Replace the new part in its housing.
  8. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 10, immagine 1 di 2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 10, immagine 2 di 2
    • Open the cap of the new part to replace the belt.
    • Tighten the inner screw.
  9. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 11, immagine 1 di 1
    • Tighten the four screws.
  10. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 12, immagine 1 di 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 12, immagine 2 di 3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 12, immagine 3 di 3
    • Replace the tip, band and handle.
Linea Traguardo
Un ringraziamento speciale a questi traduttori:
fr en
100%
HelloMacOS ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Céline Chemineau
Membro da: 01/29/20
16.608 Reputazione
95 Guide realizzate
Leroy Merlin Membro di Leroy Merlin
Community
37 Membri
239 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 142
