Salta al contenuto principale
Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser
Cosa ti serve
  1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser, Unplug: passo 1, immagine 1 di 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: passo 2, immagine 1 di 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: passo 2, immagine 2 di 2
    • Remove the dust case on the back of the device.
  3. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: passo 3, immagine 1 di 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: passo 3, immagine 2 di 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: passo 3, immagine 3 di 3
    • Unscrew the six screws from the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: passo 4, immagine 1 di 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: passo 4, immagine 2 di 2
    • Remove the four stabilisers by hand.
  5. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: passo 5, immagine 1 di 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: passo 5, immagine 2 di 2
    • The stabilisers make sense, so be careful when replacing them.
    • Replace them directly on the pad for ease.
  6. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: passo 6, immagine 1 di 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: passo 6, immagine 2 di 2
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  7. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: passo 7, immagine 1 di 1
    • Finally, reposition the vacuum bag.
Linea Traguardo
Un ringraziamento speciale a questi traduttori:
fr en
100%
HelloMacOS ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Céline Chemineau
Membro da: 01/29/20
16.581 Reputazione
95 Guide realizzate
Leroy Merlin Membro di Leroy Merlin
Community
36 Membri
239 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 379
