Salta al contenuto principale
Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement
Cosa ti serve
  1. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement, Unplug: passo 1, immagine 1 di 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: passo 2, immagine 1 di 1
    • Remove the seal on the back of the device.
  3. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: passo 3, immagine 1 di 3 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: passo 3, immagine 2 di 3 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: passo 3, immagine 3 di 3
    • Unscrew the first screw from the pad.
    • Then unscrew the remaining four screws and pull up to remove it.
    • Finally, remove the screws located on the shell of the device.
    • To remove the stabilisers you must leverage with a screwdriver.
    • To reset the new stabiliser, you just have to reposition it in your home.
  4. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: passo 6, immagine 1 di 2 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: passo 6, immagine 2 di 2
    • Replace the hull of the sander, taking care to properly position the stabilisers in their housings.
  5. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: passo 7, immagine 1 di 3 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: passo 7, immagine 2 di 3 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: passo 7, immagine 3 di 3
    • Replace the pad by positioning it perfectly in the tips.
    • Screw the four screws
    • Then the last screw. Finally, put the joint back in its place.
Linea Traguardo
Un ringraziamento speciale a questi traduttori:
fr en
100%
HelloMacOS ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Céline Chemineau
Membro da: 01/29/20
16.785 Reputazione
95 Guide realizzate
Leroy Merlin Membro di Leroy Merlin
Community
38 Membri
244 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 313
