Salta al contenuto principale
Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement
Cosa ti serve
  1. Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement, Unplug: passo 1, immagine 1 di 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 2, immagine 1 di 1
    • Remove the seal on the back of the device.
  3. Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 3, immagine 1 di 3 Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 3, immagine 2 di 3 Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 3, immagine 3 di 3
    • Unscrew the first screw of the pad.
    • Then unscrew the four remaining screws and pull up to remove it.
    • Finally remove the screws located on the hull of the device.
    • This step is the same for both carbons.
    • Wedge the two carbons to be able to take out the rotor. Reassemble them with a screwdriver, then with another screwdriver press the tab.
    • Lift the carbon and with the other tip of the screwdriver, twist the small leg.
    • Then remove the carbon.
    • Remove the rotor by lifting the frame to be able to retrieve it more easily.
  4. Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 6, immagine 1 di 1
    • Pull out the switch for more space.
    • Remove the LED from its housing using pliers
  5. Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 8, immagine 1 di 2 Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 8, immagine 2 di 2
    • Desolder the two black and red wires to be able to change the part.
  6. Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 9, immagine 1 di 3 Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 9, immagine 2 di 3 Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 9, immagine 3 di 3
    • Resolder the new LED.
    • Then replace the LED in its housing, taking care to put the cables back in their path.
  7. Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 10, immagine 1 di 3 Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 10, immagine 2 di 3 Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 10, immagine 3 di 3
    • Replace the switch, the rotor in its housing. and unlock the carbons.
  8. Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 11, immagine 1 di 3 Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 11, immagine 2 di 3 Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 11, immagine 3 di 3
    • Replace the cable, the sheath must arrive between the two studs and the sleeve must be positioned in its housing.
    • Replace the shell of the sander, taking care to position the stabilizers correctly in their housings.
  9. Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 12, immagine 1 di 3 Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 12, immagine 2 di 3 Dexter 220W Corded Multifunction Sander - 220MFS2.5 LED Replacement: passo 12, immagine 3 di 3
    • Replace the pad by positioning it perfectly in the tips.
    • Tighten the four screws.
    • Then the last screw. Finally put the gasket back in place.
Conclusione
By the end of the guide you will have successfully replaced the LED.
To reassemble preform the steps in reverse.
Un ringraziamento speciale a questi traduttori:
fr en
100%
HelloMacOS ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Céline Chemineau
Membro da: 01/29/20
16.842 Reputazione
95 Guide realizzate
Leroy Merlin Membro di Leroy Merlin
Community
38 Membri
246 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 263
