Salta al contenuto principale
Dewalt DCF885 Brush Assembly Replacement
Cosa ti serve
  1. Dewalt DCF885 Brush Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Press the battery release button at the top of the battery.
  2. Dewalt DCF885 Brush Assembly Replacement: passo 2, immagine 1 di 1
    • Pull the battery away from the tool.
  3. Dewalt DCF885 Brush Assembly Replacement, Motor Assembly: passo 3, immagine 1 di 1
    • Remove the eight 18 mm Torx Security #10 screws.
  4. Dewalt DCF885 Brush Assembly Replacement: passo 4, immagine 1 di 1
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. Dewalt DCF885 Brush Assembly Replacement: passo 5, immagine 1 di 1
    • Disconnect the connector from the motor assembly.
  6. Dewalt DCF885 Brush Assembly Replacement: passo 6, immagine 1 di 1
    • Pull the motor away from the brush assembly.
  7. Dewalt DCF885 Brush Assembly Replacement, Brush Assembly: passo 7, immagine 1 di 1
    • Lift the brush assembly out of the drill case.
  8. Dewalt DCF885 Brush Assembly Replacement: passo 8, immagine 1 di 1
    • Pull the armature assembly apart from the brush ring assembly.
  9. Dewalt DCF885 Brush Assembly Replacement: passo 9, immagine 1 di 1
    • Pry the two circled connectors apart from the brush ring assembly.
  10. Dewalt DCF885 Brush Assembly Replacement: passo 10, immagine 1 di 1
    • The brush assembly is now removed from the drill body.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Can you tell me the exact model number of the unit in this tutorial? And/Or the part number for that switch assembly? I cannot find that specific switch assembly anywhere! Thank you.
Derek Tombrello - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 35
Tutti i Tempi: 2,278
