Salta al contenuto principale
Dewalt DCD778 Forward/Reverse Switch Replacement
Cosa ti serve
  1. Dewalt DCD778 Forward/Reverse Switch  Replacement, Battery: passo 1, immagine 1 di 1
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Forward/Reverse Switch  Replacement: passo 2, immagine 1 di 1
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Forward/Reverse Switch  Replacement: passo 3, immagine 1 di 1
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Forward/Reverse Switch  Replacement, Forward/Reverse Switch: passo 4, immagine 1 di 1
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Forward/Reverse Switch  Replacement: passo 5, immagine 1 di 1
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Forward/Reverse Switch  Replacement: passo 6, immagine 1 di 1
    • Remove the drill mechanism from the shell.
  7. Dewalt DCD778 Forward/Reverse Switch  Replacement: passo 7, immagine 1 di 1
    • Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
    • To replace just pull the switch out and put the new one in the opening.
Conclusione
Brittany
Membro da: 03/09/19
693 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 46
Tutti i Tempi: 1,672
