Salta al contenuto principale
Desktop PC Left Panel Replacement
Cosa ti serve
  1. Desktop PC Left Panel Replacement, Left Panel: passo 1, immagine 1 di 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Left Panel Replacement: passo 2, immagine 1 di 2 Desktop PC Left Panel Replacement: passo 2, immagine 2 di 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
Conclusione
Altre 23 persone hanno completato questa guida.
David Lennon
Membro da: 04/14/15
9.944 Reputazione
10 Guide realizzate
Cal Poly, Team 4-5, Maness Spring 2015 Membro di Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Membri
45 Guide realizzate
3 Commenti
What is the name of the case used in this tutorial?
Nicolas Hunter - Replica
I would also like to know, I saved one of these from a junk pile but not sure what it is? Was able to fit a full ATX board with gtx570 and a little breathing room so not too shabby for how small it is.
Wabbajack Wabbajack - Replica
I have this same case in black and want to know what model it is.
numanair - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 70
Tutti i Tempi: 5,350
