Salta al contenuto principale
Desktop PC GPU Replacement
Cosa ti serve
  1. Desktop PC GPU Replacement, Create an Anti-Static Work Area: passo 1, immagine 1 di 1
    • Minimize exposure to items that can charge up and produce static electricity.
    • Use an anti-static wrist band.
  2. Desktop PC GPU Replacement, Turn Off Computer: passo 2, immagine 1 di 1
    • Power off PC via Windows.
    • Switch off Power Supply
  3. Desktop PC GPU Replacement, Unscrew Case Side Panel: passo 3, immagine 1 di 2 Desktop PC GPU Replacement, Unscrew Case Side Panel: passo 3, immagine 2 di 2
    • Put screws where you wont lose them
  4. Desktop PC GPU Replacement, Unplug Power Connector to GPU: passo 4, immagine 1 di 1
    • Be gentle to not pull with to much force when removing power cables.
  5. Desktop PC GPU Replacement, Flip GPU Lock on Motherboard: passo 5, immagine 1 di 1
    • Try not to touch other components.
    • Gently pull the card out of the slot.
  6. Desktop PC GPU Replacement, Insert New GPU: passo 7, immagine 1 di 1
    • Verify that the notch in the connector matches the motherboard before sliding in.
    • Carefully slide in GPU until you hear a click on the motherboard.
  7. Desktop PC GPU Replacement, Connect Power Cables: passo 8, immagine 1 di 1
    • Insert wisdom here.
  8. Desktop PC GPU Replacement, Re-Attach Side Panel: passo 9, immagine 1 di 1
    • Use same screws from step 2.
    • Flip power supply switch back to on.
    • Plug in PC and turn on.
    • If PC does not post go back through the steps to see if you missed something.
    • Go to manufacturer's website or use the CD that came with the card to download the latest drivers for the GPU to ensure better stability of GPU.
    • Enjoy your new GPU.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 76
Ultimi 30 Giorni: 273
Tutti i Tempi: 694
