Salta al contenuto principale
Desktop PC Front Fan Replacement
Cosa ti serve
    1. Desktop PC Front Fan Replacement, Left Panel: passo 1, immagine 1 di 1
      • Unplug the computer from the power supply before any maintenance or disassembly.
      • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
      • These screws can usually be removed by hand.
      • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
      Chiedi a FixBot
      Aggiungi Commento
    2. Desktop PC Front Fan Replacement: passo 2, immagine 1 di 2 Desktop PC Front Fan Replacement: passo 2, immagine 2 di 2
      • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
      • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
      Chiedi a FixBot
      Aggiungi Commento
    1. Desktop PC Front Fan Replacement, Front Fan: passo 3, immagine 1 di 2 Desktop PC Front Fan Replacement, Front Fan: passo 3, immagine 2 di 2
      • Push to unlatch three grey connectors on the front panel.
      Chiedi a FixBot
      Aggiungi Commento
    2. Desktop PC Front Fan Replacement: passo 4, immagine 1 di 1
      • Disconnect the front panel from the computer face.
      Chiedi a FixBot
      Aggiungi Commento
    3. Desktop PC Front Fan Replacement: passo 5, immagine 1 di 1
      • Remove four Phillips #2 head, 5mm screws holding in the fan.
      Chiedi a FixBot
      Aggiungi Commento
    4. Desktop PC Front Fan Replacement: passo 6, immagine 1 di 1
      • Slide the fan out from the side of the casing.
      Chiedi a FixBot
      Aggiungi Commento
    5. Desktop PC Front Fan Replacement: passo 7, immagine 1 di 1
      • Disconnect the power cable from the fan.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 39 persone hanno completato questa guida.
David Lennon
Membro da: 04/14/15
10.198 Reputazione
10 guide realizzate
Cal Poly, Team 4-5, Maness Spring 2015 Membro di Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Membri
53 guide realizzate
2Commenti sulla guida
My two bottom connecters holding the face of my pc case have screws in them. Problem is that I can't fit a screw driver in the gaps to remove the screws! Any tips?
Jimmy Jam - Rispondi Condividi
I did this with my pc and I was able to restore and add a new fan because the other one wouldn’t work because the wire was snapped so I decided to replace it and this guide helped me
TechNinja - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 29
Ultimi 30 giorni: 182
Tutti i Tempi: 31,702
