Salta al contenuto principale
Denim Jeans Inner Thigh Replacement
Cosa ti serve
  1. Denim Jeans Inner Thigh Replacement, Inner Thigh: passo 1, immagine 1 di 1
    • Use a simple back and forth pattern with the needle and thread to close the holes.
    • This step is to ensure the shape of your patch. It will not be the outright fix to the problem.
  2. Denim Jeans Inner Thigh Replacement: passo 2, immagine 1 di 3 Denim Jeans Inner Thigh Replacement: passo 2, immagine 2 di 3 Denim Jeans Inner Thigh Replacement: passo 2, immagine 3 di 3
    • Use an embroidery hoop as a stencil to trace out the damaged area.
    • Use fabric scissors to cut along the back panel of the jeans. Follow the line.
    • Cut only the back panel or you will have an unnecessary hole in the front of your pants.
  3. Denim Jeans Inner Thigh Replacement: passo 3, immagine 1 di 2 Denim Jeans Inner Thigh Replacement: passo 3, immagine 2 di 2
    • Place the cutouts in the denim swatch.
    • Trace a larger shape of the cutout.
    • Use fabric scissors to cut out the patches.
  4. Denim Jeans Inner Thigh Replacement: passo 4, immagine 1 di 3 Denim Jeans Inner Thigh Replacement: passo 4, immagine 2 di 3 Denim Jeans Inner Thigh Replacement: passo 4, immagine 3 di 3
    • Center the old denim onto the new patch.
    • Trace vertical and horizontal lines on denim by using a straight edge and some chalk.
    • Pin the old denim in place.
  5. Denim Jeans Inner Thigh Replacement: passo 5, immagine 1 di 1
    • Using an embroidery needle and an embroidery floss add stitches into the patch.
    • Use a Straight Stitch (just up and down sewing) following the vertical and then horizontal lines.
    • The embroidery floss comes as a twisted rope. You have to pull the threads from the rope before you can use them.
  6. Denim Jeans Inner Thigh Replacement: passo 6, immagine 1 di 1
    • Pin the patch with as little of the new patch showing as possible.
    • Use a Whip Stitch to attach the patch. This is an over/under sewing pattern.
    • Repeat a second time.
    • Turn inside out and trim down the patch. Use a straight stitch to tighten up any loose spots.
  7. Denim Jeans Inner Thigh Replacement, Finished: passo 7, immagine 1 di 1
    • The style is meant to look rustic and DIY. By no means is it a professional finish. Still functional and if done right can be quite cute!
Conclusione
This is a rustic or unfinished but functional looking patch for denim jeans.
Altre 3 persone hanno completato questa guida.
chennaultsara
Membro da: 01/24/19
197 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 72
Tutti i Tempi: 5,460
