Salta al contenuto principale
Introduzione
Ever want to disassemble and reassemble your Delphi MyFi XM2GO portable XM radio? Follow this guide to learn how to remove the motherboard (PCB logic board) of the Delphi MyFi XM2GO portable XM radio. You will need a Torx T6 screwdriver to complete this guide. Warning: you may have to use your fingernails to pry off certain parts.
Ricambi
Nessuna parte specificata.
  1. Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: passo 1, immagine 1 di 3 Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: passo 1, immagine 2 di 3 Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: passo 1, immagine 3 di 3
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
  2. Delphi MyFi XM2GO Motherboard Replacement, Battery: passo 2, immagine 1 di 3 Delphi MyFi XM2GO Motherboard Replacement, Battery: passo 2, immagine 2 di 3 Delphi MyFi XM2GO Motherboard Replacement, Battery: passo 2, immagine 3 di 3
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
  3. Delphi MyFi XM2GO Motherboard Replacement, Motherboard: passo 3, immagine 1 di 2 Delphi MyFi XM2GO Motherboard Replacement, Motherboard: passo 3, immagine 2 di 2
    • Remove the four screws from the bottom of the device using a T6 Torx screwdriver.
  4. Delphi MyFi XM2GO Motherboard Replacement: passo 4, immagine 1 di 3 Delphi MyFi XM2GO Motherboard Replacement: passo 4, immagine 2 di 3 Delphi MyFi XM2GO Motherboard Replacement: passo 4, immagine 3 di 3
    • Remove the button cover on the back of the device by prying it up with a spudger or your thumb nail.
  5. Delphi MyFi XM2GO Motherboard Replacement: passo 5, immagine 1 di 3 Delphi MyFi XM2GO Motherboard Replacement: passo 5, immagine 2 di 3 Delphi MyFi XM2GO Motherboard Replacement: passo 5, immagine 3 di 3
    • Remove the two screws under the button using the T6 Torx screwdriver.
  6. Delphi MyFi XM2GO Motherboard Replacement: passo 6, immagine 1 di 2 Delphi MyFi XM2GO Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove the back cover.
  7. Delphi MyFi XM2GO Motherboard Replacement: passo 7, immagine 1 di 2 Delphi MyFi XM2GO Motherboard Replacement: passo 7, immagine 2 di 2
    • Remove the power button by pulling it to the left.
  8. Delphi MyFi XM2GO Motherboard Replacement: passo 8, immagine 1 di 2 Delphi MyFi XM2GO Motherboard Replacement: passo 8, immagine 2 di 2
    • Remove the plastic antenna extension connector on the right side of the device.
  9. Delphi MyFi XM2GO Motherboard Replacement: passo 9, immagine 1 di 3 Delphi MyFi XM2GO Motherboard Replacement: passo 9, immagine 2 di 3 Delphi MyFi XM2GO Motherboard Replacement: passo 9, immagine 3 di 3
    • Pull up on the motherboard to remove it from the device.
    • The LCD screen and keypad are only connected to the motherboard with ribbon cables. They will hang down as the motherboard is removed.
Conclusione
Scott Byer
Membro da: 09/03/2012
61 Reputazione
5 Guide realizzate
Clemson, Team 1-2, Benson Spring 2012 Membro di Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,378
